If someone has a 1500 stripped down to the frame on the left side I need some measurements of where exactly the stud for the reverse lever is located. Measurements from the rear upper motor mount bolt hole center to the stud center and from where the strap that goes over the top of the tank bolts, center of that bolt hole to the center of the reverse lever stud.
I am making a SE out of an interstate for Lopeha and need to know where to weld the stud on.
Thanks much to whoever can help.
