Mechanical fuel pump check, bad valve?
483 Views 2 Replies 3 Participants Last post by  ding dong
I removed top of fuel pump to check diaphragm. I also checked in and out valves. "in" valve doesn't close completely, I could suck air out of it.
"out" valve is perfect.
I have 7 psi electrical pump, is that too much?
1 - 3 of 3 Posts
7 PSI may be more than the float valves can handle. You could try it and let us know if it floods or not.
Which bike are you referring to? If the 1000, the pressure is rated at 2.5 lbs. 7lbs is too much.
1 - 3 of 3 Posts
