1 - 3 of 3 Posts
I'm into the "06 Wing for the first time. I've got the meter cover off, but how do I disconnect the tweeter wires? I can't see any type of lock clip on the connectors, and fear using too much force. Help!
See those little rubber dust covers over the tweeters? And the little black pin connectors under them that go into the tweeters? On the side of the pin connector will be a small tab that you simply press in and unlock the pin connector and it will slip right out. It is quite small and really does not look like a tab, but it is there. Push on it and the connector will come apart very easy.
Kit
Thanks. I had the tweeter covers off, but the tabs are cleverly located on the inside of the connectors, so they can't be seen. I got them off when I knew they were there.
1 - 3 of 3 Posts
