On a 1500 there really isn't much to get a timed spark... How much are ya loking for (just the ignition, or are ya looking for help with starting, running & signal lights, etc), and for what model (SE, INT)?
Just to get the ECU to support idle isn't too much at all (I'm working with an SE module here from a '93 - Hopefully you kept the plug ...cause wire colors are all I've got to go by). I'll arrange 3-sets of bullets here for ya as "ECU Power", "Timing Input", "Coil Output". there's a lot more to the ECU, but when you get this far, post back and we'll over the other sensors (for timing) and the solenoids (ACIV and Air Jets)... Cool?:
Get a little power to the ECU this way (don't connect the 12V until you're ready to start it up and you're certain that nothing is shorted to anything else...)
- Solid Green wire goes to chassis/battery ground (ECU Ground)
- Black with White stripe goes to 12V (ECU Power) - ignition switch!
- Green with White stripe should go to a chassis ground (kickstand safety)
Let's try the bare-minimum (runs like poop) sensor wireing next
- Green with Black wire is a sensor common line (NOT CHASSIS or BATTERY GROUND!), the "other" side of the sensors return on this wire...
- White with a Yellow stripe wire is for the pulse generator White with a Yellow stripe wire (nice match, eh?)
- White with a Blue stripe wire is for the pulse generator White with a Blue stripe wire (sense the trend?)
- The solid BLUE and solid YELLOW wires (one per pulse generator) should connect to the Sensor Common wire (Green with Black stripe from above)
Then the coils - You'll need one connection that's NOT on the ECU for these:
- 12V power enters all 3 of the coils on a Black wire that has a coil-specific colored stripe (these 3-wires at the coils all get +12v switched). You'll wanna kill power to this wire when the bike is off, and also ensure that there's minimal resistance in this wire. Plan on 15Amps -- often this can be relay switched using the ignition switch
- Each of the coils has a Yellow wire with a coil-specific color stripe. These Yellow striped wires will match yellow striped wires at the ECU. I believe that the coil-specific stipe colors are red, blue and white - good luck finding the Yellow wire with a White stripe... these will be easy at the coils (you can see 2 easy, the third wire is whatever is left-over). At the ECU these wires are all located close to each other on one end of the connector - so hopefully not too much difficulty.
That's all there is to a non-sensored, not-safed ECU... should be enough to idle until you run outta fuel in the carbs.
You can drive the fuel pump directly off the ECU by using the Black wire with Blue stripe (the ECU will switch this for ya, but ensure that the ECU +12V power supply & wiring is good enough to carry a few amps... 10A should be fine)
After you get this far, working the 2 temperature sensors, the gearshift sensor, and the solenoids should go easily - but it'll be best to idle first and move forward from there.
Let us know.
