1 - 12 of 12 Posts
I recently sold my '97 GL1500SE / Lehman Trike. I sold the '85 GL-1200 last year. Extra mufflers were rusty so they were binned.
I have the following stuff now un-needed:
Five 40 amp GL1500 Relays never used, bought them @ GWDocs as spares ... (OEM were rated 20 amps). $10 each
one set of nice GL-1500 engine guards, these are '98 and back type. $50
one set of nice GL-1500 saddlebag guards. $15
one set of GL-1500 Alternator Brushes. $5
A K&L rebuild kit for GL-1200 or GL-1500 rear master cylinder. $5
A clear "headlight protector" with three suction cups to fit GL-1200.
Two Chrome Red lense accessory lights (would look great on a hitch rack). $10
I have a few GL1500 good but used U-joints & driveshafts & some new brake pads. $10 each
I have a still good Honda OEM GL-1500 alternator. $50
I have a Comp-U-Fire alternator that works fine but needs a new shaft front oil seal (not the large O-ring, but the shaft seal), and I even have the seal. $100
I have a new set of Honda alternator drive cush rubbers. $10
I have three Emgo oil filters and two Honda oil filters for the GL-1200. $10 all 5
One set of un-altered GL-1200 Timing belt covers intended to be used if I did the PoorBoy Mod $20
One pair of alloy 3 groove serpentine belt pulleys I intended to use if did PoorBoy Mod, one is 1.825" OD, 0.670" ID for Alt, other is 2.875" OD, 0.750" ID for crank pulley, will need adapting. $20 for both.
At some point I'll be stripping helmet head sets out of my helmets as no one wants to buy a used helmet. I have some tour jackets too.
If you see something listed that you need/desire, PM me here.
You pay shipping.
I may come up with more in time.
323382
323383
323384
Discussion Starter · #2 · (Edited)
Bought a 6 position fuse holder block to add circuits I was gonna add on too, but didn't. Brand new in wrapping, I'd take $15. Has fuse assortment too.
I'm gonna strip the headsets out and package in ziplock bags, all are J&M, some will be FF style, some open face style with boom mic, each with cords. I'll keep the helmets for snow-blowing, voting, or just because?
I'll also maybe list some "old" but like new Hondaline retroreflective Gold Wing jackets (green, maroon, black too, light up when light hit's them) and a pair of Silver & Black Honda Tour Jackets but first I gotta check with a buddy here. Mine were XL, wife's were M or L as I recall.
As allways, buyer pays shipping.
1993 GL1500 Aspy 1980 GL1100 STD
What are you asking for the Headsets?
I'll get them out and see what I have, FF, etc. I'll say $30 each set.
Buyer pays shipping.
It'll be a day or two before I get them out, have a fellow coming tomorrow for reloading stuff I need to dig out.
Put me down as interested in the open-face boom-mic style if you got 'em.
  • Like
Reactions: CrystalPistol
Discussion Starter · #6 · (Edited)
Update … the OEM alternator, the Comp-U-Fire alternator, the OEM alt brush set, the cush drive rubber set, two seals for the CuF are all spoken for, if it falls through I'll relist them.
We'll do, I know I have at least one ... and very likely more, you are the first to inquire on head sets. I'll so note.
Added note 08-08-20:
Much of the stuff in my initial listing is spoken for and in the process of sale / ship / etc, if any falls through I'll relist the item(s) … however I have the following stuff still un-needed:
I also removed mention of tour jackets as I need to sort through that stuff and I have a buddy wants some of it.
You pay shipping.
Discussion Starter · #7 · (Edited)
Didn't know I could still edit prior post, now can't delete this post, can only edit it? This was NOT intended as a bump, I just wanted to update listing but did it with edit to above post.
Discussion Starter · #9 ·
All gone except for:
One pair of alloy 3 groove serpentine belt pulleys I intended to use if did PoorBoy Mod, one is 1.825" OD, 0.670" ID for Alt, other is 2.875" OD, 0.750" ID for crank pulley, they will need adapting. $20 for both.
One set of un-altered GL-1200 Timing belt covers intended to be used if I did the PoorBoy Mod $20 (I never did)
A 6 position fuse holder block to add circuits I was gonna add on to the trike, but didn't. Brand new in wrapping, I'd take $25. Has a fuse assortment too. I sold the trike first.
As always, buyer pays shipping. If I move it, fine, if not … none of it takes up much room. The Jackets I mentioned earlier, I'll list later separately in a new thread.
I recieved your engine guards and installed with no problem. WOuld you have the radiator grill?
Discussion Starter · #12 · (Edited)
The pair of alloy 3 groove serpentine belt pulleys … ETC … have SOLD & have been SHIPPED.
I only have remaining:
A) … The one set of un-altered / un-cut GL-1200 Timing belt covers intended to be used if I did the PoorBoy Mod.
$20
And
B) … A 6 position fuse holder block to add circuits I was gonna add on to the trike, but didn't. Brand new in wrapping, . Has a fuse assortment too. I sold the trike first.
$25
1 - 12 of 12 Posts
