.... many of us add it to our Breakfast cereal... and it is also "known " to releive the heartbreak of Psoirasis... LOLOLOLOLOL/forums/images/emoticons/big_grin.gif...... To gently clean the carbs... two "glugs" per tankful , for about 3 tanks should result in a great improvement ... if the problem was related to gummed, or sticky carbs... (MMO will not cure electrical running problems... YET .../forums/images/emoticons/confused.gif LOL...) and if your starter pawl is sticky, or you want to use the detergent qualities of MMO i your oil... drain about a quart.. add a quart of MMO, and run for a200 to 300 miles.. drain and remove all the oil, , new filter, and add new oil.. and there you are !!!............................. MMO is a thinner , ATF oil.. and it probably is not so good to run around with this in the engine for long periods of time... but it cleared up my gungy starter pawl problem ... and it brought all sorts of YUCKY crud/forums/images/emoticons/shock.gif out of the engine , after only 200 miles... SilverDave /forums/images/emoticons/emoticonsxtra/cooldj.gif
