1 - 15 of 15 Posts
Just a quickie question guys, I ran a search but didn't find what I needed on the first page.
Last i bough Honda Moly... the tube was $9 and was only about a third full. I have heard rumors of other brands that offer "tubs" at much better pricing.
Can anyone direct me...
T
I use the locktite moly paste. Amazon is usually cheapest price unless you find someone local cheaper. 8oz/@$21 plus shipping
I usually get 2 to save on shipping.
I haven't used it but the LocTite brand seems to be an alternative. It isn't cheap either. Your right though the Honda tube I got was only about half full as well. The site at the bottom talks about that under the spline lubricants.
Moly greases with 60% + molybdenum disulfide content:
  • Honda Moly 60 paste, $9 for 3oz, pn 08734-0001 at your Honda dealer, or $8 from Kim Leong, STOC 3073, California Sport Touring.
  • LocTite Moly paste, 65% molybdenum disulfide. $20 for an 8oz tube from Enco, part #505-1197, 800-873-3626
  • TS-70 Moly Paste, 4 oz. ctg. $14 from TSMoly. (800) 508-5545
http://motorcycleinfo.calsci.com/Shaft.html
I have never used Honda Moly 60. I use Valvoline Moly Fortified HD Chassis grease specified for FoMoCo vehicles. It is high temp grease for all sorts of apps, it isn't as expensive, and I have yet to see any evidence that it doesn't work as it's all my GL1200 has seen in spliones since 1995 anyway when I bought it and first serviced it.
Last 16 oz can cost me $3.99. Honda Moly 60 is NOT 60% Moly, below is the MSDS for it.
Official "Cheeky Plonker"
You only ever have to use the slightest little bit, the stuff is so heavy centrifugal force generally throws off what it doesn't need. leaving a mess that's downright nasty to clean up, 4oz should last you forever if you put it on right!
Good replies... thanks guys.
CrystalPistol: They have that brand at my local Autozone for about the same price... and like you I looked at the MSDS and found it to have 15 to 20% moly.
I have run several searches online to fond a MSDS sheet for the Honda 60... but that is proving elusive.
Chilidawg: The reason I need a "tub: rather than the usual 1/2 full 8 oz Honda container is I have pulled, washed and cleaned the entire drive train of the Valk, so the spline cavities are completely dry and empty. And also... I will be using it in some automotive applications I have looming. Just figured if I was buying Moly, I should get moly that works both ways.
Banned
If it's for the bike it should work for a car...
If it's for the car it should work for a bike...
Sound reasoning to me. CP's thought pattern too I suppose.
The Valvoline stuff is a good deal. I use it.
I had used this a couple of times when I didn't have Moly Paste and I gotta say, I see no difference in how much grease get slung off and how much holds on between Moly 60 and Valvoline. It rode quite and when I took the tire off after 8000 miles, there was still plenty in between the splines, no fear of it wearing off.
Just one of the guys
The MSDS Sheet shown is percent by weight. A quarter cup of grease weighs a lot more than a quarter cup of moly powder. The 60% moly rating could be by volume, it likely would work to be similar to the 20% by weight.
I have a can of Moly powder, I just mix it with some good quality grease to make the amoune I need.
I've been using Sta-Lube Moly-Graph with good results... Just serviced the drivelines on both my bikes, and found no discernable wear after 20k miles on each; been using it for 100k so far on one of them. It's less than $10 for a tub at Pep Boys
Oh - THAT guy...
I know it was not the subject of the post, but I also have used an automotive grease on mine, the high temp red from Vavlvoline. When I last looked at my splines at Austone install (89k on bike, red grease since 15k when I bought it) they looked dandy. I had a thread with pics here a while back, but I think the conversion made it go away?
Options anyway, that is all.
Oh - THAT guy...
Discussion Starter · #14 ·
It is my experience that advice from Alex is usually good advice. I bought a tub of Valvoline Moly from Autozone yesterday. (Thanks CP) I am going to try to have the rear end on my fat girl re-packed by the weekend. I have a sizable order due from Cyclemax soon and the Dynabeads are due in by the end of the week.
Time to put the Valk back together...
It is my experience that advice from Alex is usually good advice. I bought a tub of Valvoline Moly from Autozone yesterday. (Thanks CP) ... etc ... Time to put the Valk back together...
I sometimes think I'ld like to have a Valk myself .... or a naked 1200 or 1100 .... and you are Most Welcomed Sir! ;)
1 - 15 of 15 Posts
