1 - 3 of 3 Posts
95 Aspencade SE
So Work Continues on my 95 Aspencade. Have the rear wheel off and replaced the tire. Cleaned up final drive splines and started to look into Moly Paste online. Turns out Honda Moly 77 is Hellishly expensive so wondered what other options there are.
After a bit if searching I located https://www.amazon.ca/Loctite-234227-LO ... 263&sr=8-1 from Loctite.
Did a bit of further research and found Loctite's Technical Info on the product at [/url]https://krayden.com/technical-data-shee ... paste_tds/[/url].
Turns out the product has 65% Moly but still kinda spendy at $85 Cdn on Amazon.ca.
On a hunch I called my local auto parts supplier and they provide the identical product for $39.00 and change, delivered to my door.
Eight Ounces for less than $40.00 is in my estimation a lifetime supply for cheap and at 65% moly it exceeds Honda's minimum Moly 60% so will do nicely.
While you are in there consider replacing the o rings,they fail and grease gets out of where it needs to stay.
1 - 3 of 3 Posts
