I am putting the enginefrom a 97Aspencade into a 90SE and i am wondering if everything will fit or if notwhat will i have to take from the 90 engine and put on the 97. Appreciate all the info i can get.
Jim
Jim
Hello and welcome to the forum. Sorry I don't have an answer but have to ask the question...Sounds like Both motors and Both Chassis are good from your 2 options so why perform an engine change at all? Just curious.
Senior Guru
The later engine will fit. The later engine takes the speed info from a camshaft sensor. You will just keep using the wheel sensor on your older bike.
Thanks GW.i appreciate the info ,i have the dreaded rattle can noise coming from the transmission.Do you know if the carbs from the 97 will be ok to leave on ?? Jim
I would say use your old carbs Jim, there are some electrical connector differences on the later ones that can take a bit of working out. If yours are good, keep using them.
Thanks Jason i appreciate your help ,,my carbs are workingok ,,so no problem
Jim
