1 - 12 of 12 Posts
Hey guys, it's been way too long since I've been in here. Have had problems with my password. So now that I've got that straightened out, I need some help.
I'm looking to purchase a bike cam and I need some advice on which one to buy. Must be less then $200.00. And do me a favor, please don't list a bunch of them and say 'check these out'. I have been checking 'these' out. It's like everything is good until I start reading the reviews. then you get these two or three people that hate it. One of them that I'm looking at is the
Motorcycle Camera,P6F, Waterproof,150°Super Wide-Angle Lens,Front and Rear Camera Both FHD 1080P, WiFi Support,Moto Dual Sport Camera, Sony IMX323 Chip,2.0 Inch Screen by MOTOCAM PRO
I'm looking for someone that actually has a cam and can tell me the pros and cons of that particular model. I've had some good fortune in here with some of you guys actually knowing what your talking about. And I can say, my expertise is not that great. I would like to have the best night vision I can get also. And at least a 128GB SD card.
So thanks guys.
Since this post is neither buying nor selling, suggest moderators move to a discussion forum.
I have this motoprocam:
https://motoprocam.com/collections/frontpage/products/motoprocam-dual-1080p-motorcycle-dvr-camera-system
I am not a videophile so my needs are simple. Initially I had issues with duration of the individual files. Couple tries at software changes w/o resolution. New unit with new firmware solved this. I do have the accessory GPS. The lat and long on the recordings seems accurate but the speed display is not reliable (shows I'm moving when clearly stopped - maybe an earthquake?). The downloaded software that shows the video alongside a map plot is useless. If it displays at all, the audio is choppy and unintelligible. I do not use the WiFi. No need to view on the fly.
I needed to use a small card to do software loads (16mB) but once running I have used 64 and 128. I bought a couple cards from them to ensure they were fully compatible though, at their suggestion, I bought a new 16 locally to load software changes. They were very insistent on using new cards formatted in their DVR.
I mounted one camera under the nose and one on the shelf between the trunk and rear fender. Using their mount the front one could hit the fender. I used one of the GoPro arms to move the camera up and forward which gave enough clearance. If I had a trunk rack I would have mounted the rear unit higher to clear the trailer. You need a clear line of sight as the wide angle lens will pick up body work.
I would say this meets the basic need of a dashcam and records evidence in case of collision which is what I wanted. I save some videos and compare against my GoPro. Similar but I'm not ready to start a career making movies using either method.
Average Goldwing Rider
What do you want to do with it? I use a couple of GoPro cameras. For the GL I use a helmet mount, the CB I use a chest mount. Among other uses, I like to make ride videos. The challenge is editing. A fairly powerful computer is needed.
I used GoPro for a while and still do from time to time. I liked the idea of automatic on/off and looping. Install and forget, no charging, nothing to deal with.
I had the GoPro in various locations including on top of the helmet. I can feel the extra wind resistance from the helmet mount.
On a positive note, with the GoPro on top of the helmet and the record light blinking, I noticed on a handful of occasions where I stared at a car getting ready to blow a yield sign and they then stopped. Whether the red light actually got their attention or they recognized they were being recorded I don't know. I also don't know they wouldn't have stopped anyway. Just a curiosity item. And yes, this was when I had HID bulbs and no modulator.
I own a wasp action cam. Comes with a wrist control, is water resistant without an extra case. I really like the quality of the videos. AND it is much cheaper than a GoPro
Garmin offers some really neat small Dashcams.
they include an automatic snapshot in the event of a sudden stop, it captures 1 minute prior to event, and records 1 minute after the event.
that is then stored in a folder titled "Events"
I used to mount a not so expensive digital camera, then I bought a couple of weird looking w-shield cams for like $7 each off ebay, cheap, but a hair better than none, they do have IR and a movement sensor for when the car was parked, etc. …
... & then I bought a Go-Pro, but then other issues cropped up in life and I forgot about them all.
I had the GoPro all figured out, but I'd have to start all over now.
I've had 2 dash cams. Both were junk. It took me a while to get through the Chinese-English on how to work them and then they went ****-up. I'd sure like to have a working dash-cam. Those bastards in cars are definitely trying to kill me and if one does, I'd like him to do prison time. A dash-cam would assist in that regard.
the discussions that I have had with LEOs, is that unless they personally see it, it did not happen...
although when I was run off the road and into the outside berm, and stopped a local city officer, he said that if I had a video that showed the oncoming vehicle cross the center line, and a rear camera was able to catch the license plate, and IF video logged the GPS coordinates so they could verify the location.........
then, they would be able to cite him for Reckless Driving.
But, he could not take the film because it occurred just outside of city limits, so I would have to take it to the Highway Patrol headquarters.
and if on a County road, to the Sheriff's Office.
end of story.
Wheel Witness and the Garmin dashcams work flawlessly.
Wheel witness was one of the cams I tried. It disintegrated from vibration - on my GL1500 mind you. The seller refused to fix it because using it on a motorcycle voided the warranty. The camera itself seemed to work OK but the mount is incredibly flimsy.
1 - 12 of 12 Posts
