1 - 15 of 15 Posts
Can I make the bike higher by adjusting the shock?
If so which way do I turn it
Clockwise, Counter clockwise
Many thanks
2012 GL1800
The F6b has a manual preload adjuster. It really does not increase the height of the bike very much. Maybe 3/8 inch.
Adjusting it changes dampening of the shock. More or less load.
Trike Master
The FB6 does not have an adjustable shock! It has a hydraulic controled preload pump. As stated above the height does not change very much
It does not change the dampening of the shock, only the preload on the spring.
The front suspension Showa 45mm fork and rear suspension Showa shock with adjustable spring preload. You only control the preload adjustment on the spring.
Trike Master
Sorry the preload adjuster is run by a hydraulic pump, it is not manual
2012 GL1800
which means you pay the dealer to just throw it in the trash.
That and the fact that the parts fiche DOES NOT show that part separately.
You have to replace the entire shock assembly for about $700.
324965
Or get one from a trike conversion. The only difference is the manual adjuster.
2012 GL1800
Isn't the F6B shock nitrogen filled? Hence the nitrogen adjuster. I don't see any fluid reservoir on the adjuster.
The adjuster is the fluid reservoir, like the fluid reservoir on the goldwing except it's manual instead of having an electric motor. The goldwing shock also has nitrogen in it. The shock has a hydraulic cylinder on it that extends to put more preload on the spring.
1 - 15 of 15 Posts
