i had a discussion about if goldwing had 2 speed transmission there was someone gave me info on a mechanic located in edgefield sc . would be thankful if i could his name again thank you
02 GL1800 w/Auto Pilot
his name is Sean Burch, has a motorcycle business there.
he hangs out on Facebook
go back through the threads that you have created, his full info is there
Not sure if this is what you're looking for. It's not a goldwing, but it's the only two speed I've heard of in a bigger Honda.
Back in the 70s Honda made a 750 four cylinder with a 2 speed automatic. No clutch, but you had a foot shifter to change from low to high. It was a commercial flop however and still not worth anything to most people. I see one for sale sometimes and the seller thinks he's found a gold mine.
Rayjoe
Honda Guru
Just to correct all the info about the 2 speed transmission.... it was only on the CB900C/1000C The 900C/1000C had a shaft drive, the CB750C had a drive chain. The 900C was a success in some sorts. It actually sold pretty good.... sold better than the CB900F. It was more of a cruiser model and didn't do too bad but wasn't a screamer on the acceleration or on the track. I've got 2 or 3 of the sub-transmissions if anyone is wanting to play with them. Make you a good deal!
Rayjoe
Thank you
Rayjoe
I bought a wrecked 1978? CB750A Hondamatic in 1979. My dad and I welded the engine cases back together and welded the end back on the crankshaft that holds the rotor on for the alternator. I rode it for a year and sold it to a fella with one arm. I loved the bike, It was smooth. It was not fast, It would go 60 in low and what ever in high. It had a parking brake under the seat and went into neutral when the kickstand was down. No tack, just a green light for 1 and 2 (low and go). It had an accelerator pump. I could turn the throttle 3 times in the morning and Just touch the starter button and it was purring. SOHC. Single disc in the front that looked good and that was it.
I have a picture of the engine all apart in my apartment on a tarp.
I will always remember that bike.
David
