The information is spotty and inaccurate for this example......:stumped:
Note the "Interstate" .... same errors repeated on the '81 also....
1980 Honda GL1100 Innerstate Gold Wing
Manufacturer - Make - Model - Year: Honda GL 1100 Innerstate Gold Wing 1980
Motorcycle Style: Touring
Engine
Type: 1085 cc, liquid cooled, Boxer Four , 4-stroke
Engine Bore and Stroke: 75 mm x 61.4 mm
Valves 2 valves/cylinder
Claimed Horsepower: 81 hp (60.4 kW) @
7000 rpm
Maximum Torque: 88 Nm (64.9 ft. lbs) @ 5500 rpm
Transmission
type: 5 speed
Final Drive: Shaft
Tire
- Front: 110/90-19
Tire - Rear: 130/90-17
Brakes - Front: dual
232 mm discs with
2-piston calipers
Brakes - Rear: single
250 mm disc with 1-piston calipers
**shd be 275 and 300 respectively**
Seat Height: 795 mm (31.3 inches)
Wheelbase 1605 mm (63.2 inches)
Fuel Capacity: 20 l (5.3 Gal)
Dry Weight (without fluids):
266 kg (
586.4 pounds)
**673 lb.**
I'm sure there are others but I'm done now, point made....
