1 - 20 of 24 Posts
I don't need them now, but I came acrossed a deal. Two Elite 4's, $286, plus a $50 prepaid Visa for buying them. That figured out to $118 bucks apiece. That's dirt cheap, and I'd buy Dunlop's anyway when the time came to re-shoe my bike. Tire prices go up, they ALWAYS go up. My past history with them, I got a stack of old Elite 2 and 3's, so I know them. So- Gimme your $.02 about my thoughts. Decent idea?
I wish they fit my 1800 as I would take that deal.
Check the date in the sidewall of the tires. Most of the time tires go on sale when they get a little age on them in the store. And if you plan on buying them and holding onto them for a while, the date may change your mind?
I don't think the E4s have been in production long enough to worry about that.
You are Correct Dave, I just checked and they were first introduced in April, 2016.
Junior Grue
I always get suspicious when a deal seems too good to be true.
As he didn't give a link to the deal I can only guess that it's the classic bait and switch where when you go to order you have to select the tire size you need.
Then:
The front tire you've selected is an extra $125.00
The rear tire you've selected is an extra $150.00
It can quickly becomes not such a good deal.:surprise:
Discussion Starter · #8 ·
Here's the site-https://www.motosport.com
I checked, there's no bait and switch. There is such a thing called refusal. If some dope says X tires can't be had for that price, I have no issues refusing purchase of them. A local dealer some years ago quoted me a price on some Metzler 880's. He got them, then increased the price on me. I walked out on him. Hope he sold them, because I never bought another tire from him.
Now it's $400+ and no visa card
The Elite 4 is considerably better than the previous Elite 3. The Elite 4 tread pattern is almost a duplicate of the Avon tires I have been running for many years. I have several friends running Elite 4 tires on GL1500's with great results.
I have E4's on my 1500 and love them. Great handling and about 4k on them with very little sign of wear and my chicken strips are about 3/4" wide (pegs dragging won't let me make them smaller). Very good traction in the rain and they are quiet.
Sent from my SM-G930P using Tapatalk
I would not be afraid to buy them, then store them in my basement away from sun light, heat sources, electric motors, stacked up on a pallet likely. I'd look them over, but likely they'll be OK. Likely that's close to how they have been stored.
I put Elite IIs on my 1200 in 2004, it still wears them and it's been parked in that same basement when not ridden. If I keep the 1200, likely will put Avons on it. I know ..... I should ride her more but I have worn some tires on the Trike. Last couple years, since late Spring 2016, unable to ride for the most part ... but the time is coming.
I just install E4's on my 1500 and so far I hate them!!! Michigan roads are horrible, but they seem to ride very rough and like to follow the grooves really bad.. My E'3s never did that.... I have 36 pounds in the front and 41 in the rear... Maybe wrong tire pressures????
Piaggio MP3, was 02 GL1800
up the front tire pressure to 42 minimum,
and the rear at 44
it will be a tab bit rougher, but not much, and it should help with the tracking.
You are probably not the first to notice that. I wouldn't put a donlop or a bridgestone on a wheel barrow myself.
2003 GL1800A
I've never noticed any tramlining - not even a little bit - and I've run them across the country four times.
1 - 20 of 24 Posts
