1 - 9 of 9 Posts
I bought a 1975 GL1000 about2 months ago. It needed new paint and a good cleaning andnew tires. I put around 350 miles on it and then trouble hit.
popping ang backfireing I found this forum and I think I have read every page. by doing so I have now located the problems . some one had the carbs off and when i open them up i found that the float stop had been broken off that and the air cut off needs rebuilt. I have parts on way and should be riding again within 2 weeks. Another bad thing was Thunder in the Valley was this week end and I had no bike to ride :X.. So thank you all for the help that you did not know you gave. Great Fourm . Thank you again. I will post a photo when I get it up and runing again.
:waving::waving:Welcome to the Best Goldwing Site on the Internet, grayfox!:waving::waving:
Glad to see you posting! Also glad the forum was of use to you. Hope you get back on two wheels soon.
grayfox,
Welcome to the site! When I got my '85 1200A, I found the place and like you I read all the listings. I picked up a LOT of info!! Hope you get it running good soon!
Hello Greyfox
Your problem with the backfire appears familiar to me. As you might know, the classic wings always hadproblems with the points. I frequently experienced backfiring or missfiring.I replaced the points and spark plugs several times. Then the engine ran fine for a short time only. After long troubleshooting for several weeks, because it only happened frequently, I found one of the 2 wires (blue and yellow) ofthe connectors which are connected to the points bad. That shorted to the housing. After replacement of the wires I had no more missfire since.
Welcome to the forum Grayfox and keep us informed on your progress.
I now have the carbs rebuilt , new points, new plugs,valves set, timing set, I even had a shop check the carbs. Now I still have a miss every now and then and a lite back fire out the exhause when going down hill like pop poppop // runs great and idles great at 900 rpm / Oh yea I did check all wires for a bad one and a short found none.
Got me I have done everything any Ideas ?? :?
Love this old bike alot of people ask "what year is that" . I think I will look for another one this winter ( Toys ya know )
My bike is running excellent. Rebuilt carbs, new points, timing belts, tuned up, etc. I still get popping out the exhaust. I'm thinking that the culprit is aftermarket float valve needle/seat, ie, not a tight fit. However, i get 50+mpg on the highway, and the plugs read perfect. Go figure. The only other thing i might do is replace the battery. Weak ignition and fuel delivery are kryptonite for these bikes. Glad it's running great! PS...i'm also thinking that the points breaker wires (blue/yellow) running to the coils might be a slight problem, as mentioned by Classico. Doing static timing it was hard to get the test light bright always -- maybe a short...Electrics can mask carb troubles...
Discussion Starter · #8 ·
hope this photo works . It runs :clapper:put 87 miles on it today and all works GREAT. I went over everything again and I found 1 bad wire (plug) that was green ( Green plug thats bad ) cleaned it and IT RUNS . will put another 50 on her Fri. Thank you all for the help. Have any of you ever came to Thunder in the Valey in Johnstown Pa. ? The Newspaper said we had 180,000 people this year.
Grandchildren in photo
1 - 9 of 9 Posts
