I had done this early spring of 08 and thought I would share. It may not be the best or most attractive, but it has worked excellently, even on a 5,700 mile trip with NO flaws.
First, I removed the emblem on the key switch Bridge. Then had to make another piece to replace it, using some 1/4 in. thick plastic and then I used a "Rail Bracket" to hold it in place. It needed to be cut ( with tin snips) to form a tab to fit in the existing slot on the bottom side of the Bridge. Drill it to fit the 2 screws also.
http://i260.photobucket.com/albums/ii35/winger77/Tips%20and%20repairs/100_3336.jpg
Nowon the top side, I pop-rivet another"Rail Bracket" onto this. But first I flattened out the ears so my GPS would sit flat against it.
http://i260.photobucket.com/albums/ii35/winger77/Tips%20and%20repairs/100_3338.jpg
Now mount a "RAM Mount" Whitehorse Gear - RAM Mount: Garmin i-series StreetPilot, zumo, and nuvi 200 and 700 Series Holder to the bracket.
The GPS will snap on at this point,,,,,,,,,, but it needs to be supported at the bottom. A little Velcro and cutting one of those (foam drink holders that keeps your can of soda cold) did the trick.
http://i260.photobucket.com/albums/ii35/winger77/Tips%20and%20repairs/100_3339.jpg
http://i260.photobucket.com/albums/ii35/winger77/Tips%20and%20repairs/100_3340.jpg
http://i260.photobucket.com/albums/ii35/winger77/Tips%20and%20repairs/100_3341.jpg
I'm not very good at explaining, so I hope the pictures make it easer to understand. I used what happen to be laying on the shelves in the garage. It was only going to be a proto type,,,, but works so well,,,,, why change it?
