21 - 26 of 26 Posts
Still a winger at heart.
Discussion Starter · #22 ·
You should always use leds that match the color of the lens... I used amber behind amber, etc.
I like that, would work well for something I want to do, but question : once you make the cuts in the original tape, is there any problem in re-attaching wire leads ?
Discussion Starter · #24 ·
If you've done any small soldering you will be ok. I used flux to prep the surfaces.
I mounted the strips on a backer so I could glue the wires in place to stabilize them once soldered.
Thanks. Soldering not a problem, learned that years ago with knightkits !
That's going to be my fall project now.
Price is certainly right.
You can also use a 100 OHM Resister, and 2-1 AMP Diodes on each light to make them dual purpose (Park/Brake, or Park/Turn Signal).
You would need one of these on each light to make it dual purpose. They cost under $1.50 each to make, or you can order them for $7.00 each.
21 - 26 of 26 Posts
