1 - 3 of 3 Posts
Hi All,
I am in the process of converting my 1981 gl1100 to single carb. I have the round tube manifold from Lithuania and a Chinese 34 pict3 carb. My question is, what port on this carb should the vacuum advance line that used to connect with carb 3 be on?
TIA
Kevin Valentine
Sent from my SM-G935V using Tapatalk
1993 GL1500 Aspy 1980 GL1100 STD
You are looking for a port that has little to no vacuum on it at idle but pulls a vacuum when you blip the throttle or rev up the engine....
  • Like
Reactions: valentine.kevin2
1 - 3 of 3 Posts
