When I pulled out the battery bracket on my '84 Aspencade to refurbish it I found a small black box dangling on wires behing the 30 amp fuse. The box is about 3/4 inch by 1-1/2 inch by 2-1/2 inches. There is a four conductor wire connector pluged directly into the body of this box. I didn't like the idea of this bouncing around in there so I used a nylon wire tie to attach it to the battery bracket. I haven't been able to find anything in the manual to tell me what this gizmo does.
When I pulled the bracket there was a bit of a rubber sleeve attached to a flange on it that appeared to be of no use and may have been whats left of a larger rubber mount that may have held the mystery box. It was located directly above the 30 amp fuse mount.
