1 - 12 of 12 Posts
HELP i just installed a kuryakyn mud flap on 2003 GL when i turn right singal light two lights in flap flash left signal ok
Is it a plug and play or do you have to wire it in?
Best if you start your own thread since this one is on something else entirely.
Piaggio MP3, was 02 GL1800
I merged the posts from the other thread into this newer thread.
And as DaveO430 said, you need to always start new threads to get proper attention and help for your own problems.
Welcome to your forum mach831
Can you elaborate a bit more on what you have and is happening?
Well, assuming that it does not have some type of turn signal feature, I would then have to assume it is wired incorrectly, so it sounds like you either chose the wrong plug if it was a "plug & play" installation, or you chose the wrong wire to splice into... :needahug:
Les
Discussion Starter · #9 ·
mud flap
i just put a kuryakyn mud flap on my 2002 gl and when i turn on right turn signal the two light in mud flap flash too put left on and all is ok its plug and play mud flap....
Gregarious Greeter
Welcome:waving:mach831
1 - 12 of 12 Posts
