They work quite well o my GL1100I... There are several inputs (to the self canceling box) that have to be correct.. That is the 7 volt power... the speed sensor...an angle/turn sensor.. then internally to the box, a timer.. even when they are all working correctly, you will probably have to reset the turn signals after you slow down... I learned (by a 7 volt regulator failure) that removing the 7 volt input to the box makes them manual set and reset... but I actually think that they work quite well..
