Hello all,
I have a '79 GL1000 Goldwing with 48000 miles on it that has a maddening problem. Let me begin by telling you it's service record. This spring, I rebuilt the carbs, installed new timing belts, replaced the points, plugs, and condensor, and set the timing to specs. It was running perfectly.
Monday, my son and I set off on a road trip to Mount Rushmore and the surrounding areas and, after 400 miles of perfect riding, called it a day. The next morning, after another 120 miles, it dropped the RH cylinders anytime it was below 3000 rpm. Once the bike was cooled down, it would run fine again. There is no smoke and it runs fine at road speed. I took it to two different dealerships and after scratching their heads, and various other places, could not come up with a solution. Perhaps the fact that my bike is older than the people working on it had something to do with it. After giving up on the dealerships, I loaded into a U-Haul van and brought it home. The next morning, of course, it started right up and ran fine. Not willing to risk doing any engine damage, I've parked it until I come up with a solution.
Is it possible that I've got a ignition coil breaking down when it gets hot? I'm convinced it's an ignition problem, and the coils, wires, and resistors are the only thing that have not been replaced. Remember, it runs fine when cooled off. Problem only shows up after extended highway speed.
Any help would be greatly appreciated!
Del
Del
