Having a problem need some help !!!
I have a 1996 gold wing SE with 60,000 miles; if i go 70 mph for an hour or so it seems to bog out. When i pull over and let it idol down then its fine for the rest of the day. I checked the vaccum gas valve and its ok but the gas filter onlt fills up quarter of the way, is there a reason for this.
Anyones input or suggestions on how to help or solve the problem will be greatly appreciated..
jlc
Monkey with a Football
Hot day and fuel below half in the tank?
Anti-Guru
There's always gonna be a bit of air trapped in the filter's housing.
You may wanna replace the filter with a known clean OEM unit, but I'd not suspect the air volume as being an issue there.
I'm thinking more that the filter may be restricted which could exasurbate a closing vaccum petcock (during low-vacuum conditions), and also Rudy's thought about the failing/weak fuel pump...
Try bypassing the fuel shut-off valve/petcock.
