I'm a little confused. This is my first shaft drive bike and I'm doing alot of overdue maintenance. Stearing bearings, wheel bearings, Brake pads etc... I should have taken some close up pics of things before I started, but I didn't. Now I have a spacer that goes somewhere on the rear axle. When I put everything together, it just doesn't look right. The instructions you gave for changing the stearing head bearings were great. You wouldn't hapen to have instructions for removing and replacing the rear tire? I'm at the point where my family is getting scared of me. (garage temper tantrums).
I know the spacer your talking about. It fits perfect inside the wheel, but that's not where it goes. It fits on the left had side between the rear fork and the other spacer. Look carefully at the pictures that were sent and you will be able to see it. Drove me nuts because I would tighten everything up and the wheel would rub. Did it 4 times before I saw where it really went.
Jerry
