its a sad moment
I got my radio of and did the aux input mod just to make sure all was ok before re install I pluged the radio on the bike all was great UNTILLLLL :lash: I have accidently dropped the two wires that are mounted on the aux switch i guess it toutched a ground on the engine and that was it .......
both fuses are good radio is working but low output and distorded sound grrrrrrrr (actualy ) volume is a little better with switch in on position but stays on radio i dont get aux anymore
Now I took the relay out back to oem just by the 4 wires and the cassette play fine but radio is distorded grrrrrrrrrrrrrrrrrrrrrr
I guess I blew up somethin in the radio circuit
Sounds like a job for Sierra Electronics in Nevada. They do good work at reasonable prices. I don't have their number but do a search on this forum there are several here who have used their services with nothing but good results.
Norm
Did you check the 5 amp fuses in the relay box behind the fuse panel? One of them controls the volume.
Sierra is in Ohio
Email: [email protected]
Phone: (800)338-6938 Fax: (937)339-6671
Sierra Electronics 2080 Experiment Farm Rd Troy, Ohio 45373
Ya Stu the very first thing I did and hope,,, was a fuse I did check both and good sniffff
Molon Thanks I have sent a radio to Sierra in the past and they are good
I am mad at my self i was finished and all was great just a stupid second of negligence and there i am loosin my radio for a few weeks and 150$... cant win them all
thanks guys
Norm
Sierra is in Ohio
I have been thinking about doing this to my 93 se.
They set it up with a plug for the MP3 and CD right??
Thanks Kurt
Discussion Starter · #8 ·
I done it my self.. easy if you can do small work with souldering iron.
i am mad because I have done it all and it was greatly working until I F**ked up grrrrrrrrr
Found a place that does radio repair on goldwing radio and CB in canada i will give him a call monday ....
