1 - 9 of 9 Posts
I just got my 2005 wing and it has about everything I want except for highway pegs. I gotta have pegs! The problem is which pegs to buy. Because of the way the engine sits I want to make sure I get good pegs that are maneuverable so I can find the right comfort zone. That engine can put out some heat and I want my legs to be far enough away from it but no scraping during the turns. I was looking at these:
http://www.kuryakyn.com/Products/460/Longhorn-Offset-Dually-Highway-Pegs
Any suggestions for the wingdinger? :)
Still a winger at heart.
Gregarious Greeter
I am 6'4" and theKuryakyn hiway pegs have me rubbing my legs against the fairing and were useless so I took them off.:whip:
Mic-o-pegs I have not tried, but look tomaybe solve the problem.:stumped:
Just tired of throwing money at the problem to see what sticks.:(
I, like you, also have a 2005 and have adapted to riding it stock.
I would like a set of highway pegs that would have my feet lower and just ahead of the stock pegs, letting me stretch my legs out.
The Mick-o-pgs seem to do this.
If you give them a try and you like them, please let me know.
you can stand on them and they will not slip because they contact the cylinder head with a rubber bumper. the arm has notches and really only has 3 positions. high low and center
If I go with the Ergo II's I have no idea which ones to get I've got it narrowed down to the model numbers 4064 and 4073. I want the one that extends away from the engine the most. Here are the pics.
Model 4073
Model 4064
Who has these models on their bikes?
the only difference is the foot peg style. I have the 4064 that has a switch blade heel rest. I do not use that part much. when I do, I use them for a toe rest while using the stock pegs. mine are position the same as your pic
the engine is not a problem for me. It is the heat from the radiators
Discussion Starter · #9 ·
I'm sorry guys. I should have posted both model numbers while they are attached to the bike. I now have the right pics up. As you can see the models are different. Which model has the peg away from the engine the most. I like the 4073 model in the way it looks.
1 - 9 of 9 Posts
