2 things come to mind, did you purge the air from the system after changing the antifreeze? And theotherthing is sometimes when changing the antifreeze, the thermostat will stick in the open position, thus needing to be changed out. I always replace the thermostat whenever I replace the antifreeze.
Welcome to the forum! I'm sure someone else will come along with some ideas also.
Gene:waving:
