Discussion Starter #1 (Edited)
WTB two tone R-176c Spectre Red Left Shelter for my 94 GL1500 SE. need some other parts if you have reddish/brown plastics.
I have in purple two tone if trade is
321434
the two tone red is color I’m trying to find new shelter in
Maybe I need a new prescription on my glasses, , , , but I'll be dam'd if I see a hole for the reverse lever. Do you????
I didn't state that quite right, what I meant, was that the 94SE with Reverse does have a hole in that side panel.
the panel shown, does not. and I did mention that panel does not have a hole for Reverse.
I recall having to remove the Reverse lever so that panel could be removed.
I had to adjust the Reverse cable a tiny bit.
I thought the 94 SE had a hole for the reverse lever, , , , hmmm
Hey, yes it does have a place for reverse to come through. It’s a black plastic piece with the hot air vent. I just removed them off the purple set
the SE does, I had a '94SE with Reverse.
That panel is colored right, but the Reverse hole is missing?
Hey bud, you’re right it does/supposed to have hole for reverse. I removed the vent assembly that has black plastic W/hole for reverse lever. I’ll post it later just to for information purposes 🤘
321433
="BLUTHUNDR31, post: 5887344, member: 285217"]
[/QUOTE]
I put the plastic vent pieces back on the purple shelter.
