edzinohio wrote:
I broke off a pilot screw in one carb. I have tried to drill it out with a series of increasing drill bit sizes. I am almost the the threads and don't want to mess it up. I need some suggestions to finish the job. The remains of the pilot screw still appear to be siezed up.
edzinohio, that's a tough problem you have there. ANYTHING you do that in any way alters the pilot needle seat or angle will really foul up your low speed fuel mixture on that carb.
If you must get it out-- Setting the carb up in a milling machine so it is perfectly straight to the quill then using a small mill bit would be best (I have done similar in my mill with good results). If you don't have access to a mill then making a small drilling fixture to press onto the needle recess to guide a small drill bit would be a good choice. Use a left hand drill bit as those tend to catch & spin the broken needle out as you get close to drilling through the broken needle.
If you can heat the area a little & work some penetrating oil in around the broken needle (from both sides)enough to allow it to come free easily, you could drill a small hole in the needle (stop short of the tip & seat) then lock-tite a small drill bit in the drilled hole in the needle & back the freed needle out using that loc-tite-ed drill bit.
Do you really have to remove it? If you can clean around it & clean the passage behind it you could probably leave it alone as more than likely you would just adjust it to the same spot when doing the final carb adjustment.
Twisty
