1 - 17 of 17 Posts
I was pulling the rear Axel and the 27 MM Box wrench from the 1500 Toolkit broke and busted my knuckles.
I admit I was cranking on it pretty hard. But I have never had trouble removing that nut before.
It could be that the temp was 11 below zero before I heated the shop up and the metal bits were quite cold.
Good thing I was wearing a pair of gloves, but I was still leaking blood through them. grin.
And it's an Awfully good thing this didn't happen on the road. I got lots of tools here, But I count on everything I carry on the bike to work.
I want the original as it becomes the handle for the 1500 tool kit case.
Anybody have an extra I could buy?
Mohawk
I thought my tool kit was missing the 27mm, but there is one and the 22mm. Does anyone know what is missing from my kit? Looks like I am missing the slide handle that fits on the wrench.
I see one on ebay with an extendable 27mm wrench used as the handle, but mine has a short 27mm already. Honda must have at least a couple of different versions of the GL1500 toolkit.
The 27mm is cheap from Honda, if you're going to be ordering anything else. I am getting ready to place a large order, let me know if you need me to get a wrench.
1997 SE Kit:
http://cheapcycleparts.com/model_years/795-honda-1997-gold-wing-se-gl1500se/assemblies/11912
#31 on the diagram
1992 GL1500 Interstate kit shows 27mm wrench as unavailable.
http://cheapcycleparts.com/model_years/599-honda-1992-gold-wing-interstate-gl1500i/assemblies/10410
Sam, Put me down for a 27mm wrench. I broke mine last year replacing my rear tire. Ended up using a harbor freight impact socket, 36" breaker bar & all of my weight to get that sucker loose. The PO must have had an 800lb gorllia put the axle nut on....PM me with payment details....-Rich
I'll let you know if the thing is even available, but it should be. May not have the cheater bar on it, but I figure a flattened piece of EMT should do the trick.
I am ordering some repair parts for my '97 late tonight sometime.
Heat up the nut with a torch . will come off easer . My 2Cents
Hey Sam, Thanks for the info. I will just order one from my dealer.
I have one from a Yamaha Venture Tool Kit, but it's longer and wont fit my kit.
In your kit, the 27 MM with the sliding flattened metal pipe becomes the handle for your kit.
I see your 27mm is nested ontop of the 22mm wrench.
I too think flattened Conduit should work.
This is the third tire change on this bike for me and I never had a problem removing that nut till now.
I kept grabbing a flashlight and studying the threads to see if maybe they went the other way like lug nuts on old Dodges. But I knew I would have remembered something weird like that.
Thanks.
Mohawk
I have the cheater bar still in my tool kit.
Just another ORF!
Sam .... if that is a picture of your tool kit, it looks like your 'slide handle' is underneath your 2 box end wrenches and feeler guages. Can't figure out what else it may be. :?
Dusty
Dusty
Yep, it's my tool kit, and yep, that's the handle for the 27mm wrench. Wonder who put it there? I should have caught it, so glad you did before I wondered even more.... Now I have my carrying handle back....
Thanks!
Sam, Did you find out if the wrench is available? Are we still on, or should I get mine separately?....-Rich
Ooooops, I am sorry, I saw the comment from Mohawk above "Hey Sam, Thanks for the info. I will just order one from my dealer.' and I thought that was you saying you would just get your own.
I'll place another order here shortly, unless you want to see if a dealer can just order it for you. It's such a small item cost wise.
Let me know though.
Let me know though.
I will order from Gary @ http://cyclemax.com/ Thanks....-Rich
I carry a 1200 Ltd tool kit in pouch in my 1500, being the best tool kit Honda ever made.
The 27mm wrench is 3/8" thick :<)
Discussion Starter #14
Ordered Mine from my Local Dealer and the cost was $3.48 plus tax.. No Shipping as it's sent to the Dealer.
I have ordered quite a bit from the local Honda Dealer and never paid shipping yet.
Works for me...
Mohawk
Just another ORF!
The 27mm wrench is 3/8" thick :<;)
While that is a beefy wrench indeed, the 27mm, the carrying handle and the 22mm wrench are designed to work 'as a team' on the 1500s tool kit and that wrench's handle would be too thick to slide the carrying handle onto.!
When I use the 27mm for the wheel, I slip it onto the axle nut, then slide that carrying handle part way over the wrench's handle, then slide the handle of the22mm one, part way into the carrying handle. It all works together like a 'cheater bar'. This gives you a lot more leverage, to unfasten the axle nuts, or to give them the required amount of torque when tightening them.
Rudy said he's never seen them used in that combination before, when I showed him this 'technique' this past summer. :?
They work well together.
Hey great tip!
Monkey with a Football
Yep. Just leave it up to Chuck the Canuck to blow your mind about the time you think you have him pegged.
That was a memorable surprise there.
I like those. :claps:
1 - 17 of 17 Posts
