1 - 3 of 3 Posts
I have a 2010 GL1800 with a Motor Trike Adventure Kit. I had to take out the axel and replace a torn CV boot. Now going back together I can't find the torque specs for the Axel Nut. Does anyone know where one could get a repair manual for this kit, Motor Trike is less than helpful!
Any Help is appreciated.
I’ve run into this issue before also where no torque specs are available. What I did was check the torque on the other wheel with your torque wrench and match it to your side of repair. This allows you to take note and write it in your repair log book. Be careful not to over tighten the opposite side, just use enough pressure to notice a slight, minimal movement if any. “Got to start somewhere? “Good luck and happy riding.” 😉
1 - 3 of 3 Posts
