Need Water Pump for 83 Aspencade
489 Views 5 Replies 4 Participants Last post by  Nightrider1
I am looking for a water pump for an 83 Aspencade. Mine went bad, and the one I took off of my 80 GL1100 parts bike is weeping coolant. Very, very little.If you have a good onefor sale, Pm me. Mine is an 83 GL1100.
Thanks,
Nightrider1
PS.
If you know how to rebuild one, what would U charge me? I might go that route.
I'd go new, Nightrider...you don"t want to do that job twice!
OEM is around $150.
OEM is around $150.
And the new OEM's have the metal impeller now instead of the fiber one.
Thanks Mike!
I found one on E-Bay for 35.00 Guarenteed. I'm gonna give it a shot. I read somewhere you can put teflon tape wrapped 4 times tight under the water 0-Ring. That seems spooky too me.
Thanks,
Nightrider1
Hereis an OEM from a Honda Dealer for $119.66
Wow. Sure is a lot less expensive than I thought. I am rebuilding everything I can do this winter on the 83 Aspencade. So Far, New Belts, Head Gaskets, Getting water pump, and going to change out the theromstat and radiator. Carb sync coming up Friday Morning. Replacing both head light switches, Horns, Windshield, (Now On) Just rebuilt carbs. The radiator does not leak, but I cannot see any coolant flowing when the Theromstat opens??? or fan kicks on. I wanna make sure this is ready for next year, and then, my 80's gonna get a new Paint Job. The ex Mechanic that worked at Honda for 20+ years I got helping me can get OEM parts for my 80 or 83 at cost plus 10 %. Just cannot beat that. At least I am not getting any coolant into my oil now, nor oil in my radiator. Glad I got that solved. If this water pump doesn't work ok, I will order an OEM one. I figure it would be better to put in a new water pump, and have the one off Flea Bay as a spare.
Good Luck,
Nightrider1
