Needed 1979 GL 1000 rectifier and regulator
Well after my 1000 mile trip, good thing it is after not during, the battery is not charging. The battery was purchased new just before my trip. Stator checks good. I am getting no readings for the forward bias on the rectifier and the reverse bias seems low. I am not sure if the regulator is bad. Can you test the regulator if the rectifier is bad?
I do get 40v @ 2800 rpms on the yellow wire going to the regulator. That voltage drops as the rpms go down. I have 10+ volts on the black wire.
Thanks for any help.
