putting engine back in i have two wires dont know about..one goes on netural switch and the other on temp switch???one is black with red trace and the other is blue???i think the black with the red trace goes to netural switch and the other one to tep switch.need help!!!
The Irish Crew
I don't remember the colour of the wires, but the one to the temp sender is a single wire with a bullet connector. You can check if it's the right one by grounding it and seeing if the temp gauge needle shoots up.
al they both have bullet connectors..havent got that far yet with hooking everything back up to put battery back in yet???
the thermo is blue.
the neutral is black & red
this is from 82aspen.
thanks wda went back out and found the po had cut plug off the thermo switch found all the wires.THANKS AGAIN..great site for help when your in doubt!!!!!:bowing:
