1 - 20 of 26 Posts
Hi follks, I am looking at buying a 1987 aspy. when i took it for a test drive the other day i had a hard tiime getting it to go into neutral after the ride, is this normal on the wings? or is it just something that takes a little finesse. thanks in advance, i'm learning alot from this GREAT goldwing site.
When I bought my 84 GL1200 it had floorboards with heel toe shifter and it was hard to find neutral. I went to the stock pegs and shifter and shifting to neural was no trouble at all.
On my 85 1200a, sometimes it is hard to get neutral, but other times, it is easy. I figure it is the way I shift and a normal thing. :baffled:
By the way, WELCOME:clapper:
The loose bolt can cause the problem. I learned long ago to try to shift to neutral while still rolling. Too loose a clutch cable can also cause the problem.
Hi,
Try getting into neutral just befor it comes to a stop. Also, I beld my clutch line, made finding neutral a lot easier, also eliminated clutch drag.
TOJ
Hey lboodge,
:waving:Welcome to the Best GoldWing Site on the WWW:waving:
My 1984 Aspy has the same problem. When it is cold, it will slip right into neutral. When it gets warmed up and after a ride, neutral is a little hard to find, sometimes.I too have found that if I shift into neutral just before stopping,it seems to go in a little better.
I've always found it easiest to shift all the way down and then lift a toe for neutral. Like most bikesit takes a littlefinesse with the clutch to go through the gears while stopped.
 I have found that neutral is a lot easier to "find" , on MY 1200, even with Heel & toe shifter, for about a month after the Annual MMO oil treatment ... lots of gunge comes out, and neutral seems to "pop" into place , for a while.. SilverDave /forums/images/emoticons/emoticonsxtra/cooldj.gif
my harley will ONLY go into neutral this way, from second gear it is straight to first heading down. As mentioned above all bikes can be hard to shift when stopped. I am sure all of us have stopped at a light with out down shifting and then have had a heck of a time getting into first gear.... it is esepcially hard to do if you are wearing your kilt at the same time.
Lboodge, if you are new to that bike it might take a little while to adjust to finding neutral.. On stubborn ones it sometimes helps to take it down into 1st then back up into neutral..
If the clutch bushing in the hand lever is worn that can also make finding neutral difficult as the clutch doesn't then fully release.
Those older Wings also can get air into the hydraulic clutch system & that alone can make finding neutral with it running a real pain..
Probably not a major problem there but just a little looking (or familiarization) will show the problem..
Twisty
If at a dead stop, try a little rev of the throttle and as the rpm's drop down it'll slip into neutral.
Kyle
Along these lines....when I pull in my clutch and am sitting at a stop light with the bike in gear, if i rev the motor a little, the bike will start to move forward. I have the clutch all the way in but it still wants to move forward. If at an idle, it is fine. What gives?
the wet sump clutches want to do that, that is also why when you first put it in gear you will want the barkes on, and why it is best to start it in neutral as well. nearly lost my harley starting it in gear and the clutch not all the way enaged
If it does it with the engine cold it's justlubrication fluiddrag on the clutch plates, but I've never noticed that on either of my Wings when warmed up. Wonder if a little clutch bleeding ceremony might not be needed? How far does the lever come in to release the clutch? Could possibly be something to do with the type and weight of lubrication fluidyou're using too. Notice I did not mention o*l?
1 - 20 of 26 Posts
