I read that with these symptoms, it shows the switch is still good, but the neutral switch diode is shorting, causing current to flow through both the switch and the diode when it shouldn't. To test the switch first: I put a digital multimeter on the neutral switch, black probe to frame, and red to the switch center/lead. With the transmission in gear, the meter reads 'open/infinite.' When in neutral, i get a slight continuity/voltage reading (.2v). How could this be the case if the light stays on? Wouldn't i also see slight continuity from the switch when in gear to cause the neutral indicator light to remain (dimly) on? My understand is that 'infinity' reading means no current passes through. I tested both diodes and they both read 7.3k for resistance.
