1 - 9 of 9 Posts
Ok what's the trick to get the neutral switch out? I got the bolt out but how does the switch come out of the engine? I thought I had the hard part done with prying the frame out to get oil screen cover off, but noooooooo!!!!!
Get a vice grip in and grab onto the neutral switch and turn it a little bit. She will slide out after that. Had the same problem several weeks ago. Forgot to check the switch out before installing the motor in a restoration. Guess I learned the hard way! Anyway, the neutral switch was gummed-up and could not get continuity. I took it out and cleaned up and that solved the problem.
Does it matter which way you turn it or is that just to loosen it up/break the "goop" seal.
It does not matter which way. The O Ring in there just gets stuck after this many years. I put the screw that holds the wire back in and grab that with a pair of side cutters and then pry it out.
Whiskerfish, is that with the engine in the bike or out? I don't see that much room to get the screw out to get the wire off let alone grab the screw with side cutters.
Engine un bolted and on a jack but still hooked up. I used wooden wedges to shift the engine left in the frame to get clearance.
I can't tell but is the rear motor mount bolt out as well? The one under the fuel pump?
Yes. the removable frame section is off and all the mount bolts are out. The driveshaft, carbs, radiator are all in place. It is a pain in the butt of a job.
I think I'll just live without a neutral light. Haven't had it in 8 yrs and 4 yrs ago I had the insturments apart so I yanked the bulb. Thought if it wasn't a hassel I'd restore it back but screw it. I know where neutral is.
1 - 9 of 9 Posts
