I was thinking about buying or actually trading for this gl1000. what does any one think, would these older bikes be a lot of trouble getting parts. i think it is well worth $600 is it,i talked to the seller and he is willing to take a pistol in trade, i paid about 600 for it. he said the rode it 2 years ago and it has been sitting since. how much does it weigh? owner says it has 30k miles on it.
May be worth it. Go over to Randakk's site and look at some of the 1000's and read on some of them what has been done and parts availability,
Good luck on it!
Unless he put it away properly, you'll be spending a fair amount of time getting it back up to speed with the carbs gummed up and various fluids needing a changeout. It took me about a month of work on my 1100 before I could reliably ride it.
Not sure on the 1000's, but my 1100 Interstate weighs around 750#.
TECHNICAL SPECIFICATION
Model ID
Manufacturer (Make)
Honda
Model Name
GL 1000 K 3 Gold Wing
Year
1979
Category(class)
All-round
Engine
Engine Capacity (Displacement)
999 ccm (60.96 cubic inches)
Engine Type
4 cylinders
Bore x Stroke
Ø72.0 mm x 61.4 mm (Ø2.83 inches x 2.42 inches)
Bore/Stroke Ratio
1.17
Stroke
4
Valves per Cylinder
Timing System
OHC
Cooling System
Liquid
Powertrain
Gearbox
5 speed
Chassis/Suspension/Brakes
Front Brakes
Dual disc
Rear Brakes
Single disc
Front Tire
3.50-19
Rear Tire
4.50-17
Dimensions
Curb Weight
298 kg (657 lb)
Fuel Capacity
19 litres (5.02 gallons)
Performance
Max Power
78.00 HP (56.9 kW) at 7000 RPM
Power/Weight Ratio
0.26 Hp/Kg
Top Speed
196 km/h (122mph)
Acceleration (dart, speedup) time
0-100 km/h
5.5 seconds
0-60 mph
5.2 seconds
[*]1/4 mile
[*]60 to 140 km/h, highest gear
