the carbs only start and run at high rpm with engine at full choke otherwise it does. I thought maybe I would balance the carbs with my carb tune thinking the air ratio was completely out of whack now, at best I'm getting only 5% of air thru the number 3 carb the rest are flat no movement at the carb tune I turned all the screws in or out same problem.. W.t.f. Is going on I've had the carbs out twice cleaned all Reset all, I think air ratio is screwed up, I used new o rings etc I used a fatter o ring for maximum sealage still screwed up... Helppppp.
1987 GL1200 Interstate
Have you got the correct (stock) air filter installed? That can make a big difference in how carbs work.
Did you spray cleaner and compressed air through all jets and visually see the low speed ports are open.
My best guess is you have the floats set way too low, used cheap aftermarket parts and didn't get all the passages clean.
