1 - 18 of 18 Posts
I own a 1986 SEI, 80,000 mi. Changed timing belts today. I could not find timing inspection screw, but marked crank pulley when cam marks lined up. Nervous about tension on belts.
Hello and Welcome to the forum family .
the timing inspection cap is located on the top of the engine on the left side ,between the carbs and where the swingarm hinge is located . Its about an inch around and has a large slot for a flat screwdriver .
Here is a tutorial which may help you . Take this link , its on this forum :Honda Goldwing GL1200 Timing Belts Replacement
Welcome from Oklahoma :waving: Enjoy the wing :cheesygrin:
1985 GL1200 A
Forgive me, but I don't see the connection between your engine's timing and the timing belt tension....
On my '85 the engine timing is not adjustable. The timing belt tensioners ARE and when set right there should be 1/8-3/16" of movement in the center of the long run of each belt with 4-5 lbs. of thumb pressure.
Good luck!
Gregarious Greeter
Welcome:waving:Billg64
I recommend you post your question over in the technical section. Most of the gurus won't see it over here, and a lot more people frequent over there. Just a few of us greeters hang out over here on a regular basis.
:waving: :waving: :waving: :waving: :waving: :waving: :waving: :waving:
Hello from Virginia,
Welcome Aboard!!!!!
Glad to have you with us!
Hallo Billg64
And good luck with your Wing.
1 - 18 of 18 Posts
