Have 1995 gl1500 , 43,000 miles. No sparkfrom plugs,fuel pump down . Have replaced bank sensor and check all fuses. Have check and clean kill switch. Any suggestions ?
Thanks for the reply
I should have added all other electronics working. I not familiarwith the pulse generator. Can you advise of possible location.
W.McCormick
Blue Knights
Fl. 25
The pulse g. picks up a signal from the crank trigger and tells the plugs when to fire, it also does the same for the fuel pump.
It's inside the front timing belt cover.
You have two P.G so I would check for a bad connection on the P.G'ssince they use one plug for both of them.
