And if you really like cross references
Cam marking for 1000's
Auto advance stamped: 75-77 #371, 78-79 #431
Cams 75-77, no markings; 78-79 marked 431
FUEL FILTER Napa part number it's 3011 and the cost is $3.49 BUT CHEAP FILTER.
Air Filters
K & N
GL1000 - HA-0800
GL1100 - HA-8080
GL1200 - HA-8084
GL1500 - HA-8088
GL1800 - HA-1801
Batteries
Odyssey - (sealed)
GL1000, GL1100, GL1200, GL1500 - PC680MJ or PC680 (*1)(*2)
GL1800 - PC545 (*3)
(*1) MJ stands for Metal Jacket. It is not necessary to have the Metal Jacket in our applications, therefore you could use the PC680
instead.
Without the Metal Jacket, the battery is cheaper.
(*2) Battery installation requires re-routing of battery cables.
(*3) The PC545 is 15/16" lower in height than the OEM battery.
Paint 98 1500 candy apple red
Colorrite 2615
Honda R176C
Brakes and Rotors
EBC Brakes
GL1200
Rear Rotor - MD1082
Rear Pads - FA69xx
NOTE: substitute the xx above in the pad number with GG for low performance pads, FF for mid performance pads or HH for high performance
pads.
EBC Brake Pad & Disc listing for Goldwings.
Model & Year
Front Pads
Front Left Disc
Front Right Disc
Rear Pads
Rear Disc
GL1000, 1975-77
FA29
MD1074LS
MD1074RS
FA32
MD1064
GL1000, 1978 FA29
FA32
GL1000, 1979 FA29
MD1036LS
MD1036RS
FA32
MD1064
GL1100 & I, 1980 FA30
MD1036LS
MD1036RS
FA29
MD1071
GL1100 & I, 1981 FA29
MD1036LS
MD1036RS
FA29
MD1071
GL1100 & I, 1982 FA69/2
MD1036LS
MD1036RS
FA29
MD1082
GL1100 & I, 1983 FA69
MD1036LS
MD1036RS
FA29
MD1082
GL1100 Asp, 1982 FA69/2
MD1133LS
MD1133RS
FA69
MD1082
GL1100 Asp, 1983 FA69
MD1133LS
MD1133RS
FA69
MD1082
GL1200 I & Asp (5mm thick front disc), 1984-85 FA69/3
MD1083LS
MD1083RS
FA69/3
MD1082
GL1200 I, Asp, Ltd & Sei (10mm thick front disc) 1985-87 FA69/3
MD1125LS
MD1125RS
FA69/3
MD1082
GL1500, 1988-89 FA124/2
MD1126LS
MD1126RS
FA69/3
MD1127
GL1500, I, Asp & SE, 1990-00 FA124/2
MD1126LS
MD1126RS
FA69/3
MD1077
GL1500 Valkyrie & Tourer, 1997-98 FA142
FA196
MD1077
GL1500 Valkyrie & Tourer, 1999-03 FA142
FA196
TBA
GL1800 A1 & A2, 01-04 FA261HH
TBA
TBA
FA261HH
Bearings
GL1500 Rear Wheel (6204RS (driveshaft side) and 6304RS (disc side)
GL1500 Front wheel Koyo 28-6302 or equivalent (usually 6302RS)
GL1500 Alternator Bearings NSK 6000DU
GL1500 Fuel Filter VFR NT650
Wheel Bearings - GL1000 & GL1100
Front - 6302 2RS (x2)
Rear - Takes a 6204 2RS & a 6304 2RS
Readily available from any bearing distributor.
Cam Seals Honda part #91209-371-003, Oil Seal (27X43X9)
Napa #ATM 2117994, Altrom
Beck Arnley #052-2755, AutoZone
Note: x3 on 1000s and x2 on GL1100s.
Beck-Arnley from Rock Auto 052-2755
Copper Squash Gaskets (exhaust header) - (1000, 1100)
NAPA; Fel-Pro part number 60567 or 12-1002.
Oil Filters
AC Delco
GL1500, GL1800 - PF2135
AMSOil
GL1200 - SMF-101
GL1500, GL1800 - SMF-103
Carquest
GL1500, GL1800 - 85358
Castrol 73117
FRAM
GL1000, GL1100, GL1200 - CH6009
GL1500, GL1800 - PH6017A
Fram CH6017
K & N
GL1000, GL1100, GL1200 - KN401
GL1500 - KN303
GL1800 - KN204
NAPA
GL1000, GL1100, GL1200 - NAPA Gold 4940
GL1500, GL1800 - NAPA Gold 1358
Purolator
GL1000, GL1100, GL1200 - ML16809
GL1500, GL1800 - ML16817 or ML16819
STP
GL1100, GL1200 - SMO-09
GL1500, GL1800 - SMO-17
Walmart
GL1500 SuperTec 6607
WIX
GL1000, GL1100, GL1200 - 24940
GL1500, GL1800 - 51358
PISTON RINGS 1100
They come from a 1996-02 1590cc Suzuki Esteem, G16KV, G16S 1.6 Litre 75.00mm bore size 4 cylinder 2C4901 8 top and second groove at 1.2mm and 4 oil rings at 2.5mm.
http://www.perfectengine.com/Suzuki_Pis ... _s/153.htm
Radiator Hose
(Cut in half to make 2 hoses)
NAPA - 7733
Gates - 21008
Spark Plugs
GL1000 (75 - 79)
NGK Standard Plug - D8EA-9 (Gap .028")
NGK Iridium Plug - DR8EIX (Gap .028")
GL11001(80)
NGK Standard Plug - D8EA (Gap .028")
GL11001(81)
NGK Standard Plug - DPR8ES-L (Gap .028")
GL1100 / I / A (82 - 83)
NGK Standard Plug - DPR8EA-9 (Gap .035")
NGK Iridium Plug - DPR8EIX-9 (Gap .035")
GL1200 / I / A / L / SEi (84 - 87)
GL1500 / I / A / SE (88 - 00)
NGK Standard Plug - DPR7EA-9 (Gap .035")
NGK Iridium Plug - DPR7EIX-9 (Gap .035")
GL1800 / A (01 - 05)
NGK Standard Plug - BKR6E-11 (Gap .043")
NGK Iridium Plug - BKR6EIX-11 (Gap .043")
Timing Belts
GL1000 & GL1100
Gates - #5119 or #T274 (2ea.)
NAPA - #250274 (2 ea.)
Goodyear - #40274 (2 ea.)
GL1200
Gates - #5043 or #T070 (2 ea.)
NAPA - #250070 (2 ea.)
Goodyear - #40070 (2 ea.)
GL1500
Gates - #T275 (2 ea.)
NAPA - #250275 (2 ea.)
Goodyear - #40275 (2 ea.)
GL1500 Aftermarket Radiator Cap.
Stant 11233
NAPA 703-1406.
