Please bear with me. I just upgraded to a 88----1500 and i have headlight probs.When cold it works on statrup.Then quits.Bike works fine.
Don
Relay 8 is for the low beam and relay 4 is for the high beam, swap them round and see if the low beam stays on as that's the one that is cutting out.
Also worth checking when the headlight goes out, wiggle the reverse lever about. Sometimes the reverse switch goes bad and makes the headlight go out.
BTW, Welcome to the forum Don. :waving::clapper:
Couldn't hurt to squirt a little contact cleaner/lube or WD40 in the High/Low switch and work it a bit.
Senior Guru
It turns out that it was the switch Pual, as Dman posted elsewhere (he has several posts about the same subject ).
I am new on the board and want to thank all .
Don
