1 - 13 of 13 Posts
1985 Honda Goldwing GL1200
Hi all. I just picked up a fixer-upper... a GL1500. I've owned a GL1000 and several GL1200's but this is my first GL1500SE. It's an anniversary edition, 1995. It needs a little work. I'm looking forward to getting it back on the road. I was told it needs an altermator. I will test it first before I do anything. I've learned that taking people's word for it can lead me down the wrong path.
Plant Tire Vehicle Wheel Automotive lighting
Sky Plant Tire Automotive lighting Automotive tire
Tire Hood Automotive tire Car Automotive lighting
Car Motor vehicle Automotive tire Hood Vehicle
Wheel Vehicle Tire Automotive lighting Hood
Interesting in your first pic its a Honda towing a Honda on a trailer. Looks like a nice bike that needs some TLC.
I have 4 Hondas (2 cars 2 motorcycles) and 1 Alfa Romeo. Seems I gravitate towards Honda for some reason.
Hallo rlajbsmith
And good luck with your Wing.
  • Like
Reactions: rlajbsmith
Discussion Starter · #10 ·
you probably have towed a lot bikes, but leaving that kickstand down is a no no, it will causes stress cracks in the frame.
I've never heard this. I've towed at least a dozzen bikes in lots of different ways. I have a chock but I couldn't use it this time as I had limited light and had to get over to pick it up quickly before dark. Next time. However on dismount I had a ramp failure (never had that happen before). It turnd into a little bit of a disaster because I was alone, but I finally got it down without any damage.
Discussion Starter · #11 ·
I charged up the battery and tried to start it. It didn't turn over at all, just clicking. I even tried jumping it with my car thinking that maybe the amps on the battery couldn't handle the load, no go. HMMM. I'll try taking out the plugs next time and moving the rear wheel in 5th. Anyone have an easier way to turn the crankshaft manually?
Piaggio MP3, was 02 GL1800
I've never heard this. I've towed at least a dozen bikes in lots of different ways. I have a chock but I couldn't use it this time as I had limited light and had to get over to pick it up quickly before dark. Next time. However on dismount I had a ramp failure (never had that happen before). It turnd into a little bit of a disaster because I was alone, but I finally got it down without any damage.
The Goldwings are heavy bikes, and pulling down on the straps with the kick stand down, is putting a huge amount of stress on a component that is not designed for that.... I have read many posts since I joined this forum in 2006, about frame cracks after tying down the bike on the side stand.
all bikes "should be" run into a Chock to hold them vertical, and then strap down the front using the short Double Loop straps over the Triple Trees....
and never, tying down the frame period... never.... just use a single strap around the rear wheel to prevent it from sliding sideways in the trailer.
This allows the rear suspension to work as it was designed to do, absorb bumps/road shocks as it is transported.
Saw Helmet Plant Automotive lighting Automotive tire
Automotive tire Plant Automotive lighting Vehicle Tire
from the side
Wheel Tire Land vehicle Plant Car
it was raining heavy the day I brought it back home from a local repair shop, so I left it on the trailer for a couple days, just threw the cover over it fast.
those covers will NOT stay on the bike, while it is being towed. Plus, they will grind the finish off the paint.
1 - 13 of 13 Posts
