Hi yall first post be gentle. I have a 89 GW trike that the cruise hasn't worked since I got it.I can not find the control box under the seat.If its there its hidden very well.So I guess its a single search.The CRUISE ON light works but SET doesn't. Both light when key is turned on.Levers work switches ok Clutch clicks once but the brake lever only clicks once also. should it click twice? Is there a way to check this double duty single switch?I found the foot brake cruise switch.What a stinker!! I need to know exactly where the wires are to check with a meter Manual said behind the ign. control box. ok wheres that rascal hidden?? If I take off any more panels I think I can be legaly arrested in some states. As you can see I need help. Im old and stuborn and don't want this thing to beat me. thanks for listening.
