1 - 12 of 12 Posts
I am the proud new owner of an 88 GL1500. Traded off my '79 GL1000. Really like it but I find the off idle flat spot very annoying:(. I have seen references to a HOnda recall that fixed this problem. Can anyone direct me to a place (besides a dealer!) that would have the specifics of the changes required to fix the problem. I am a decent mechanic and would do the work myself if not too complicated. thanks in advance for the help. Mark in MN.
Oh No! that sounds like a big buck OEM item. True? thx for the reply
GERIATRIC MEMBER
Hey cldryder :waving:Welcome to the greatest Golgwing Forum on the net. :clapper:
There was a recall to fix that problem, probably too late now, but it might be worth pursuing.
I own an 88. If you remove the batery cover and see an x mark on the frame your bike has had the mod done.If no x go to the honda recall site and you will find all the info needed.It list the recalls and tells you how the work is to be done by the dealer and you could do it yourself
Dman
Thx for the reply and excellent info. I checked out the GL1500 recall page but get a "no such page" when I click on the link for the summary. Is this information available elsewhere. Mark in MN
style="BACKGROUND-COLOR: #f8f8f8"http://www.gwrra-ok.org/oks/service/sb2.pdf
style="BACKGROUND-COLOR: #f8f8f8"That's the dope on the problem!
Discussion Starter · #12 ·
Thanks much to everyone for the help. I should get my manual in a day or two and will check for vacuum leaks. 1st tank with sea foam helped some.
1 - 12 of 12 Posts
