Welcome to the Forum:waving:
You will probably want this shifted to the tech portion of the forum, but we might need a little more info on the symptoms:
1. Other than the light malfunction, does the bike shift normally through all the gears?
Every Honda m/c I've owned or operated, new and (ahem!
) pre-owned,has had issues with neutral lights and all have required a little bit of finessing from time to time to make the light come on (shifting back and forth through the neutral position).
2. Does the neutral light ever come on?
Good luck:leprechaun:
