Ijust bought a1989 1500. The clutch catches when I have let it almost all the way out and shifts rough. My fluid was to the lower mark and I filled it to the upper level.Any advice on the next step? Thanks in advance!
try bleeding it..
Read my post from April 30 on how I fixed mine. If you need more info just Email.
No But it made it so much easer to start off. Make sure the spring is big enough in diameter so it does not bind. also file off small amounts of the pin and try it. You only get one chance and if you take off to much you will have to buy a new plunger rod. By the way we go riding in your neck of the woods every year.
Where do you ride up here? Ever go up NC 80 around Lake Tahoma? Beautiful and curvy, and you can get on the Blue Ridge Parkway at the top, real close to Mount Mitchell.
