Check you rear brake switch located near the brake master cylinder. Maybe out
That's something that I never thought about. If WD 40 will work, I suppose contact cleaner would work also. Thanks for the tip.Those rear switches need to be cleaned regularly. I use WD-40 and just work the slider by hand.
I use WD because it alsolubricates and is not so hard on the rubber boot. It's not a matter of dirty contacts, it is the slider that sticks. Even oil will do the job.Bike...and Dennis wrote:That's something that I never thought about. If WD 40 will work, I suppose contact cleaner would work also. Thanks for the tip.Those rear switches need to be cleaned regularly. I use WD-40 and just work the slider by hand.
Terry
But doesn't WD-40 and oil "attract dirt and dust" more than electrical contact cleaner??terry_208 wrote:I use WD because it alsolubricates and is not so hard on the rubber boot. It's not a matter of dirty contacts, it is the slider that sticks. Even oil will do the job.Bike...and Dennis wrote:That's something that I never thought about. If WD 40 will work, I suppose contact cleaner would work also. Thanks for the tip.Those rear switches need to be cleaned regularly. I use WD-40 and just work the slider by hand.
Terry
May be. It's a pin that rides in plastic. I lube it so it will slide easier. When mine gives me trouble, it either just hangs up sothe pin won't slide to open the contact. Or more often now days, it opens and then won't close so the lights stay on.Bike...and Dennis wrote:But doesn't WD-40 and oil "attract dirt and dust" more than electrical contact cleaner??terry_208 wrote:I use WD because it alsolubricates and is not so hard on the rubber boot. It's not a matter of dirty contacts, it is the slider that sticks. Even oil will do the job.Bike...and Dennis wrote:That's something that I never thought about. If WD 40 will work, I suppose contact cleaner would work also. Thanks for the tip.Those rear switches need to be cleaned regularly. I use WD-40 and just work the slider by hand.
Terry
Seems cleaning with WD-40 then a shot of electrical contact cleaner to wash the WD-40 residue away would be a good idea.
Just my thoughts........
