After replacing the turn signal horn switch, the turn signal relay, hours of frustration :?trying to find a short or loose ground, God had mercy on me and directed me to apply pressure to each fuse while holding the horn button. Lo and behold, the little demon was right there hiding in the fuse box,:cooldevil: my first word was "HALLELUJAH " There is a God in heaven.:)
Once in a while the gremlins die!:cooldevil:
And so do fuses!:D
That's what was crazy, the fuse itself was good, I coulden't figure it out until I pressed down on the fuse while holding the button in. There is something loose in the fuse box itself. You won't believe the time I spent trying to solve this one. I knew it was something loose because it would come and go.
I have much sympathy for you, I spend a lot of my working life chasing intermittants.
